My truck set for about a month and the battery was dead (no obvious reason). Autozone said it was drained, but took a full charge. It still wouldn't start, turn the key, no sound, but the interior lights worked. I could jump it off and it would run fine. I had the battery double checked and it was fine, I also put the wire brush on the terminals, but they were pretty clean. Still, no start, no sound. I tried to jump it off again, and it would make a single grunt, but no start. After a few minutes, I went to disconnect the jumper cables and they were hot and burnt me (medium gauge jumper cables).
The battery ground was secured to the frame, the other end went to the wiring shroud and to the engine, it seemed ok. I ran a jumper from the negative terminal to the engine, still no start.
The starter is only 6 months old. I checked the starter wire, and there was a little play, but it seemed to have a good connection. Any ideas? I'm stumped.
