94 Toyota Land Cruiser will turn over but not crank.
Arizona
I’m having the same issue. It started after I got ran off the road and hit a ditch. It cranked up after and I was able to get out of the ditch but it was not running right. I had to keep the rpms up to it would stay running till I got to a parking lot and get it towed. Once I got it towed home it will not start the engine turns over but that’s it. Read this forum and I changed all the fuses and the efi but still nothing. Turned key to on and don’t have a cel. Any help will be much appreciated thank you.
@Trevcar Turn over and cranking is the same thing = Starter is functioning rotating the engine.
What you want to say is engine cranks but does not fire,
No CEL with key on means ECM is not powered and not ready. Base upon your description the most likely failure is the fusible links.
I would also check your battery hold down as the battery is moving around.
