'94 throttle issue
Weilerbach, Germany
My '94 will start, but idles low and if I take my foot off of the gas peddle, the RPMs will die down and shut off. The only way to keep it running is to keep my foot on the gas. Any suggestions?
A couple.
Plugs, wires, distributor cap and rotor, dirty throttle body, bad gas, etc.
When did it run properly and what has happened since? Do you have the FSM?
Could be, except that's it's not cold in Charleston.
Well, my still-unsolved problem started on a hot summer day in the northeast, and I'm just fishing for answers myself. I guess to be constructive in this thread I will add:
Intake hose crack/leak, misadjusted throttle cable, possible bad ground (at the USDS inner fender or at the TC), main harness issues at the EGR valve or at the firewall, PAIR, EGR, IAC, TPS, ECT (not necessarily in that order), and as Malleus mentioned, the FSM.
A couple.
Its been running fine, but noticed the last time I drove it, it idled a bit low. The distributer and wires seemed fine. I'm thinking throttle body, I'll follow the steps of the FSM Inspection of TB.
The mechanic thinks its a head issue on the exhaust side.
I have a 4BD2T and a NV4500 that's been collecting dust in the garage. It looks like I'll be starting a diesel swap thread soon.
That went sideways fast. Best of luck!
Seems pretty standard. Possible sticky throttle cable?
Nope, diesel swap. :banana:
I wish I had that sort of time and wallet resources laying around. :D
What's gonna happen when his tires wear out?
2-1/2 Ton Rockwell axles?
