94 LC wheel lug-nuts
Ashburn, VA
Can someone confirmed that my 94 LC lugs are torqued to 108 ft. lbs??
Thanks
Thanks
That's what the spec is, in my owner's manual & FSM. Personally, I keep mine 95-100 ft. lbs. IMHO the 80 lug bolts shear very easily and only myself will touch them. No tire shops, especially, with their air ratchets and get done as fast as possible environment.
Steel or aluminum rims? Aluminum are 76 ft/lbs.
I believe NA spec.'d 80s only came with the alloy wheels. Anyway, that's not the difference in torque specs IIRC. It's the design of the lug nuts that determine what torque rating should be. Conical vs shouldered was the distinction. But, I'm going on memory so hopefully someone in the know can either confirm or alter this.
I've been using 105Nm (76 ft-lbs) on mine. I've got the conical nuts and aluminum rims.
Cheers,
JFS III
I am waiting on my new manual from Toyota Publications, so I can;t reference it for you. I can tell yhou that I have been using 90 ft/lbs for about 240,000 miles on the factory aluminum wheels with conical nuts.
Uh oh, I upgraded from 15" OEM's to 16" OEM's and followed the Owner's Manual for the 15" wheels and went with 116 lb/ft! 3 of the wheels have conical seats, 1 of them has a flat seat. Looks like 90 lbs is the correct torque?
You would use different specs for the different lug nuts. Higher spec for the conicals. I can't quote the exact spec as I don't have a manual in front of me. Seems like it was 76 ft/lbs for the shank style and ~105 for the conical style.
Some tire shops (Costco in this case) follow a spec sheet provided by their attorneys - their mechanics may have been consulted, but who knows?
Anyway, they have the spec for 1993 Land Cruisers at the steel wheel setting (107 ft/lb?) and have the aluminum wheel setting (76 ft/lb?) for 1994 LC and up.
Since my 1993 has aluminum wheels, I just tell them it is a 1994 - otherwise they argue with you. I guess some idiot sued them for something.
240,000+ miles on the same lug bolts and nuts, with anti-seize on them. If it ain't broke........
Jack Nichols, 1993 LC
Call me crazy, but I have never once in my history of vehicle ownership used any kind of torque measuring device when torquing wheel nuts! I hand tighten them all first and then cris-cross my way around the pattern, torquing opposing nuts until they feel good and tight. This is just the way I was taught and I have never broken anything or had lug nuts come off. Am I in the minority here?
Check this website out for some answers.
Explain to someone what 'good and tight' means. You may have the right feel and are torquing them properly. You can't give that feel to someone else. Give them a torque spec and they can hit it every time. That's what Toyota did.
You may not be torquing them properly, and at some point you may hit the limit for the studs being over torqued, and they may stretch and/or break. That isn't going to happen if you follow the torque specs. Nor will you strip the threads out of a lug nut. Or have the nuts loosen. Or warp your rotors. It's too easy to do it wrong if you don't have a standard to follow, and too easy to do it right not to.
You're probably close enough to the specs when you do it by feel. Probably. I know for a fact I'm close enough.
On the matter of hitting the torque spec by feel...
From a mass manufacturing standpoint (that's what I do these days) we often define torque specs tolerances based on what our technicians can hit. Our techs have many years of tightening screws to be secure without over-tightening them. When doing torque studies, and defining torques for new assemblies we often find that our techs are all +/- only a few ft-lbs. This is all done by feel and practice.
Note however that for these applications the goal is "tight-enough without over-tightening". In this case there is an engineering reason to define the torque spec, so defining the spec after the fact is not possible. In these cases, even our experienced techs always grab a torque wrench to make sure they can report that the correct value was set on the device history record form.
