How do I tell what type of lugs I have on my 94 LC? conical or shank?
TIA
TIA
Conical on a '94
If the rim has a steel seat then it is acorn style.
If the rim does not have a steel seat then it is shank/washer style.
Where on the wheel is this "steel seat" you are referring to?
I assume "Conical" is the same as acorn style?
Yes - Grench gave you some great advice. BTW - Acorn style on stock aluminum rims torque is 76 ft/lbs.
Lug nut torque specs are as follows:
All steel wheels...109 lbft.
Alloy wheels with conical steel inserts (91-94) 109- lbft.
Alloy wheels 95-97 (shank-type nuts) 76 lbft.
