94 Cruiser stalls and code
I am now an owner of a 1994 Land Cruiser and am loving it so far. There are a few kinks I need to work out in order to have it running up to par.
When 4low is engaged and shifted into reverse, the rpms drop and either jerk the vehicle back repeatedly until more throttle is applied, or it simply stalls. This problem only occurs in 4low and in reverse.
There is a check engine light on, not sure if it is relevant to the idle problem or not but I imagine it is. Not a huge concern right now but it needs to be fixed.
Lastly, around 40 mph the steering experiences vibration and pulls slightly right most of the time. The tires are pretty bad so it could be an alignment issue but not sure if there is any common problems with the joints up front.
Like I said, I'm new to these vehicles and have tried the "search" tool but cant seem to put my finger on anything yet. Any input is greatly appreciated.
-Austin
Welcome :flipoff2:
No idea on the 4low issue.
The CEL, some autozones, checkers, etc will pull the code for free. Run down and get the CEL code and report back (71, 25,26...) To clear the code you can pull the EFI relay inside the engine bay or disconnect the battery. Your truck will most likley run like crap for some odd miles and need to turned on and off several times for the ECU to relearn.
If the tires are bad tackle that first before running down alignment and other items. Even a rotation or balance could help unless they are toast.
Welcome to the addiction. :)
Isn't there a paperclip trick on the diagnosis plug on the firewall that you can use on OBDI vehicles? Then just count flashes.
:doh: that too! :bang:
Ya, I think it is Te1 and e1, passenger side rear firewall (looks like a odbII port), pop it open with truck off, jump the two with a paper clip, the truck on (just to AC for power) watch the CEL light blink. Watch for the long pauses for distinction in numbers.
thanks for the quick responses! ill look up the "paper clip" trick and see where that puts me.
as for the tires, they are not bad from a tread standpoint, but it seems they have been sitting for a while (dryrot, cupping, ect.) Ill make the code top priority for now.
the code came back as 7: throttle position sensor signal. hoping its an easy fix and that sounds like it would fix the stall issue as well. anyone with familiar with this problem, i would greatly appreciate some input.
I have not ran across that one personally. But use the search and Im sure others will chime in.
