93 O2 sensor issues
Upstate, SC
Hey everyone,
Hoping for some insight and feedback. Have a 93 1FZ that I had fresh NKT 24080 o2 sensors put on a few months after a head gasket job last year. This solved a persistent cel 26 (I believe it was 26) that I had.
Engine ran well for a few months, then I began to have a rough idle, poor acceleration and seemingly misfire symptoms. Took me most of the summer to actually get another CEL to come on that led me to check the o2 sensors. The outermost connector was full of water when I unplugged it - checked resistance per FSM and it was not within spec. The inner sensor was within spec and had no moisture issues. Engine ran fine with that one sensor unplugged, just naturally with a CEL. Got a new NKT in, waterproofed it the best I could, and had no issues until today, where same issues popped up with this sensor being out of spec with resistance, too (no CEL yet at least, but was only driven back home a few miles). Had a few drops of water in the sensor, not as much as last time. Engine idled normally again, just with CEL back on once I had the sensor unplugged.
Am I getting knock off nkts? The inner sensor is within spec with resistance and seemingly has no issues. Any other steps or recommendations other than trying to find a Toyota o2 sensor? I am struggling to figure out how it is getting moisture in it as well as the car/ecu side of the connector has been dry and has no moisture around it that i can tell. I do have a fresh spare NKT i guess i will have to install. Something is going on with them and I can't figure it out evidently as I am blowing through O2 sensors.
Any help is greatly appreciated. Thanks
Hey everyone,
One of my dumber mistakes in the baselining of our '94 prior to turning it over to my daughter was to order a NTK 24080 off of Amazon. I was chasing CEL 26 for quite sometime and down the worst rabbit holes.
Thanks everyone. I’ll get the Toyota sensors ordered.
Any ideas on the water intrusion issues? And how to prevent it? Don’t want to keep having issues with that, especially with Toyota sensors when I get them.
I had a similar issue with water in one connector when driving mine home from AZ to MD...hit a torrential rain in Ohio and had issues until I got home. Took me about a month to figure out the issue since the 80 platform was new to me. Unplugged the connector and water just ran out of it...after a month!
I loaded my connector with dielectric grease and wrapped it with a plumbing repair silicone tape that you stretch when you wrap it and it self-seals. Been 4 years now and had a few water crossings in my wheeling trips and no issues ever.
Thats the same issues i was dealing with. I did use di-elecrtric too with the silicone tape. I will apply it again but will wrap the entire connector this time
Yeah, I wrapped mine thoroughly including up each wire pigtail to seal it completely, not just around the connector itself.
Thanks everyone! I put the spare NKT in and wrapped it with silicone tape the best I could, over the connector and each pig tail. Also moved the connector up as far up I could in the passenger fender well to try to keep water intrusion from occuring again.
I ordered 2 of the OEM toyotas as well and have it on my list to relocate them to the manifold this fall. I will keep everyone posted with what happens.
For reference, I have a 93 and put walker O2's from rockauto in the PAIR/Manifold area about 8k miles ago and haven't had a CEL. I know walker isn't loved on this forum, but so far i've had good luck.
When I did ours I have two Toyota's, one 7 years old (inboard) one much older with a bad heater circuit. I replace the outboard with an NGK from Amazon that I am pretty certain was bogus and I was pulling 25/26 codes. I then bought two new Toyota's but only replaced the outboard. The codes nearly disappeared (only once in 1,700 miles) but it would not pass inspection (high CO).
Removing the inboard was beyond me, but a shop got it done. No codes and it did really well on inspection.
