93 master in a 78
On a hill overlooking a lake in Idaho
Website
I am thinking about putting a 93 brake master in my 4 wheel disk 78. The 78 had bps on the bottom. The 93 doesn't. What does the wireing that comes out of the top of the fluid cup do? Is that a connection for Brake presure or low fluid indicator? Thanks for any reply
Larry Lee aka Plowboy
With my superior powers of deduction, I believe the wires can only be for fluid level, as there should be no pressure in the resevoir. They seem to connect to a float suspended from the cap.
Keep in mind the '93 probably has ABS. I don't know if that matters or not. 91-92 didn't have ABS if you find you need an MC without it.
I have no idea what a bps is, so if that was a question I can't help with it. :D
-Spike
As Spike said the wires are for the low fluid indicator. They use the little float that is connected to the cap to determine level.
-Spike
Looking at a MC with ABS, functionality looks the same to me. The lines just lead into the ABS motor which actuates the fluid when skidding occurs.
