93 locker question
Zionsville, IN
A 93 LC just poped up for sale and I might get it. I have been searching for threads about lockers but don't have the time before I buy it to research deep. Does a 93LC have lockers I kept seeing threads about 91-92 lockers. Some quick help would be appreciated.
Thanks in advance.
93 was the first year the lockers were available, but it was an option and not all rigs came with them. I usually ask the seller if it has a knob on the dash to the left of the steering wheel that says something like "Fr/Rr Diff-lock"
I have had people confuse a "center diff-lock" switch with the actual diff lock. not the same. CDL locks the center differential in the transfer case.
hope that helps
The other considerable difference between early and late production 93s was the 15 or 16 inch wheels combined with rear drum or disc brakes with floating axles. Also, be it minor, early 93s had an ECU that occaisionally would fail and leave you with a permanent CEL, the later ones had a different ECU.
