How would I go about taking these studs out? While doing my EGR delete, the nut came off the stud, but the double sided stud is being... difficult. Pictures attached. Thanks for your time
After thinking about it, I’m sure I can handle the butterfly job without removing the whole assembly, the heads are 6mm, but they started stripping after a good amount of pressure.Ohhhhh yes these little buggers. I wrecked a few, snapped one, and cracked the manifold on another. (Could buy new back then pretty well)
12 point socket will remove them (5mm maybe?)
By far, remove entire assembly, remove TPS sensor, and soak in penetrating oil or diesel.
The corrosion between the shaft of the galv steel bolt can fuse to the alloy.
Do they really need removing?
