93 Emergency Brake Re-install
Washington, MO
When I purchased my truck the emergency brake handle/cable was not installed. I've since traded for a replacement brake assembly. All of the parts are still in place from the mid-ship back, I'm re-connecting the forward portion into the interior including the handle and cable. Does anyone have a photo available of the brake handle mounted under the dash and where the cable routes through the transmission hump. The ebrake I have has the 90 degree cable direction change pulley. The front bracket appears to bolt under the dash, the rear appears to mount to the fire wall (inside). Then I would guess the cable runs down the interior into the transmission hump, the along the passenger side of the transmission utilizing the cable clamp on the side of the transmission. If you can explain the routing in words you can try that too. Thanks for the assistance.
Even the FSM exploded view page would be nice. I searched through the online version and couldn't find what I was looking for.
