Hello everyone,
Been a while since I last posted, now I have an issue I cannot seem to figure out and would appreciate some help or advice.
Story:
Came home from a week long vacation and went out and started my 93 1FZ to go the store. Hard start, took a couple of cranks to get going. Ran kinda rough, idle was sparatic truck was shaking like there was a cycl not firing. Sputter on start off (moving) and once I got the rpms higher it went away. Got to a stop and pressed the pedal and again sputering. Check engine light was on and pulled the codes, 83,84,85. Let sit for the rest of the day and dove into the Factory Service Manual. Found that there is an issue with TCM and then noted the ESA 1-3 Circuits. Went back out side to pull it in the shop and would not start. Turned over and over but would not start. I think these codes indicate a failure of the electronic spark advance system (ESA) the on board computer that controls the spark advance, there may be a problem with the distributor or possibly the ECU.
I had planned on giving her a tune-up when I returned from vacation and had many parts ready to install. Fuel Filter, Fuel Pressure Regulator, Spark Plugs, Wires, Distributor Cap and Rotor, Clean K&N Filter, PVC Valve, Hoses and the Main Air Intake Hose.
Before I left on vacation the truck was running pretty good, no probs or CEL just time for a tune-up.
I checked to see if the fuel pressure reg was working, seemed fine. Removed it and replaced with a new one. Started the truck and sputtered for a minute like it was going to start then died again. Tried Starting and the same...no start.
Replaced the PVC Valve and Hoses.
Pulled a Spark Plug and checked for Spark and then checked the gap and it was @ 0.04in. OEM Spec is 0.031in. Left the gap alone for now since I have spark and went back to the books. The plug looked ok, kinda dark but nothing beyond abnormal.
Still no start. Could the codes I pulled cause it not to start? I heard that the complete diagnosis for the TCM, ESA is in the book but could not find how to test it.
If anyone has experience with the codes I pulled and or the relationship between the non-starting issue I would appreciate.
If this is an ECU issue, is it fried?
Kinda long I know but I thought if I could give as much info on the situation as I could it would give everyone a better chance to help.
Thanks
Mark
Story:
Thanks
Mark
