'92 Transmission Slips Between 2nd & 3rd
Athens, GA
Website
rainmakerwebdesign.com
First, thank you all so much - this is first question I couldn't answer by lurking on this incredible community.
Bought a '92 FJ80 a couple months ago, has 215k on the clock, absolutely love it. A week ago it started slipping between 2nd & 3rd, and I'm hoping to either remedy it or at least walk into the transmission shop armed with knowledge.
Symptoms/Status:
- Mildy accelerating it slips and revs about 500 rpm before shifting
- Happens between 1250 rpm and 1750 rpm or so, if barely on the throttle it shifts smoothly (below 1250), and also shifts smoothly if harder on the throttle where it stays in 2nd above 2000 rpm
- Had significant "clunking" when going into D and R, transfer case fluid change minimized both sounds
- Kickdown: it does kick down at highway speeds, but feels like the kickdown cable may need a little tweaking
What's Been Done:
- Transmission torque converter were reconditioned 16k miles ago, has a slow drip from the pan, honestly I don't have the highest confidence in the job done.
- Have done the drain & replace method with Dexron III fluid, and the old was as clean as any fluid I've taken out of any vehicle - no shavings or anything on the magnetic drain plug.
- Fluid levels are in the middle of the hot notches on the dipstick while running.
- Also, I've tried a slight overfill (1/2 quart), and taken the fluid down a little bit to ensure an overfill wasn't causing it, and now have it back to spec (I believe).
- Have replaced the fluids in the transfer case and differentials
Is there anything I should be trying/doing before taking it in?
