- Joined
- Nov 13, 2008
- Threads
- 1
- Messages
- 1
1992 Cruiser Problems
sup fellas, i'm new to the forum. i heard this a great forum for any advice or assistance. let me tell you bout my rig, it's a 92 fj80 it has about 143,xxx. I bought from my cousin for $1,500, so far i got a new head job, replaced radiator, alternator, air housing, EFI Electrical done, so far i've been happy with my rig. i was going to get rid of it cause all these problems were happening at once. but now i think there are some minor things going on that maybe i can get some advice on. so here's my questions....
1. recently had some issues with idling. first start up, idling would be jumping from 1200 down to 500rpm up and down. i took it to shop and adjusted the TPS to manufactures setting. working good....
Question: Idle is not jumping, but where is idling suppose to start at first morning crank. I thought is suppose to start around 1200rpm then when u sit there at idle it suppose to go down between 600 and 800. Right now when i start it starts at 600 maybe at times 500.
2. replaced radiator - i noticed the coolant reservoir tank or overflow tank. well, it's not over heating temprature is and mid level all the time. but i noticed the reservoir/overflow emptying out. I fill it to full line, then after 3 days it's empty.
Question: am i losing coolant somewhere, i see no leaks of coolant, i do have a new cap on radiator. i don't understand how the reservoir/overflow tank works. it seem like i'm filling that tank up every couple days.
Hopefully i can get some advice. Thanks again.
E-
E-
If you're really sure it's not external, start checking for things like goo on the underside of the rad. cap or on the oil dipstick, which would indicate coolant getting into the oil, and sweet smelling moist exhaust, from coolant getting into the cylinders.
