92 Cluncking! Newbie Help!
Spokane, WA
Hello all! First post! New to the forum and thought I would pick your brains on an issue with a LC I am looking at purchasing. After months of searching I finally found a decent 80 for sale in the Spokane Area. It's a 92 with 89,XXX documented miles. I know the 4.0 is a dog but I'm not looking for a sports car. Excellent shape and everything checks out except one major problem. There had to be one! :crybaby:
When I put it into gear I hear and feel a distinct clunking. I then feel it as I move through the gears. Also, as I move through the gears I feel the clunking. The trans does not seem to be at fault as it does not flutter in or out when shifting or fall out of gear. This is not a gentle lurch or a nice firm shift but a real heavy THUNK. Once I'm up to speed no issues, UNTIL, I let of the gas and then put it back on, then there seems to be a delay then THUNK and I back on track. I got underneath it a could not see anything obvious, the U-Bolts seemed firm and without play, transfer cases seemed in good shape, however I AM BY NO MEANS A MASTER MECHANIC. I change the oil in my Tacoma and that's about it.
Is this a common problem with the early 80's?! :confused: Has anyone experienced this same issue? Any help or ideas would be greatly appreciated! I love this 80 and who hate to see it do, but on the other hand I am not looking to walk into some else's dumped nightmare! Thanks in advance!
It's normal on a 91-92.
Not kidding.
As an introduction to the forum, why not search threads (advanced search, 80's section only) with the keyword "clunk" and you'll see what I mean.
Welcome,
Curtis
91FJ80, 240K
P.S. Wait a minute: Only 89K?!! Dayum...
Thanks, just did a little research. Glad to hear that this is not out of the ordinary and these are a few good ideas. Any idea on the parts cost and time for the splines? Anyway glad to hear there will be some good support if I purchase. It's in cherry and I can pick it up from the idiot who has it now. I can scare him to selling it cheap with the "Clunk" as ammo. I have a friend who is a Toyota/Lexus service mechanic who can do the labor for cheap (ie lots of beer).
The big question, is it possible to eliminate the "Clunk"? I think I can pick this up for $3-4k so I would not mind dropping a grand to make this go away, I am really really picky about my cars and that would drive me crazy.
If your that picky, you may not like the 3FE or the "Clunky" drive-trane of the 80 series.
You can get rid of most clunking with a Tranny kick-down cable adj. Both the accel. cable and my tranny kick-doan were loose. That helped a lot with the clunk.
I also had worn out BIRFs, worn Drive-flanges, and needed some new u-joints in the d-shafts. My FJ had 172,000 on the clock when I bought her. You may be able to do a front axle service, grease the d-shafts, adj. the cables, and say a little prayer.
The early 80's are a little rough around the edges. The 3FE motor is often called a "sewing machine" as it sounds just like one when it's running perfectly. The whole vehicle is a slow, but powerful monster, and is often called "The Tractor" affectionately.
What are your plans for it? Expedition, off-roading, daily driving?
One more thing. Once you have the early 80 series, your most likelt going to LOVE it, and be ready to defend her against all these other newer 80 series bums... :D
I got a '92 with the same problem. Ive searched all the "clunk" threads and still dont know how I'll go about trying to solve it. I dont just want to go in and replace parts that dont need it. Im like you though, it drives me crazy. Does yours get worse as the truck heats up?
Starting to get a clear picture
I am looking at the 80 for DD and light expedition duty for the family. We moved to Spokane from PHX about a year ago and want to get out exploring next spring. I only live about 4 miles from work so I don't really care about the mileage either. And yeah, it does sound like a sewing machine, however, the idiot who has it has a cheap AutoZone distributer and ubercheap plugs and wires. I am sure that a thorough tuneup with do a lot for it.
Anyway thanks for the feedback, I am picking up my buddy in a little while and going to take him out to look at it and have him drive it around to see what he thinks and to see how low the current owner wants to go. He is asking and insane amount $8500 but I think he is freaked out buy the clunking so I am going to lowball him. Cross your fingers for me.
Here are the 3 things I would try to solve your annoying issue:
1. Grease all the driveshafts.
2. Adjust your tranny kickdown cable.
3. Drive your truck in 3rd gear all the time! no kidding, up to 60mph, Then shift
Not one of these may 'cure' it. But the combination of all three is what has helped IMHO.
Agreed with Curtis, MJ, and Jason.
However...not meaning to hijack... I keep hearing about the tranny kickdown cable. Where is it? All I see is two throttle cables.
I must be missing something here....
Lane, its the one closer to the front of the truck. There is a nut on each side of the little mounting plate. You want to move it to the passenger side. Meaning more threads will be exposed on the passenger side of the adjustment mount.
I barely have to touch the skinny pedal to get it goin. It used to feel like a brick.
Cool... <going out to do things...>
SWEET!!! I went out to check mine earlier, but then remembered that I already adjusted it!
Wow, I have REALLY gotten used to that clunk...well...minor *thud*.
Still Waiting...
So I threw in my offer $5500 tops. I had not heard back until he started blowing up my phone today. I think someone is desperite. Here is the laundry list of what my mechanic came up with.
1. Bent Pully
2. Belts
3. Oil Pan Gasket.
4. Shocks
5. Alignment
6. Drivers side mirror assembly. (it wobbles like a drunk sailor)
7. Splines (Should take care of the Clunk)
8. Exhaust leak (New muffler should do it).
9. Serious tune up. This guy has some cheap a** autozone pugs wires and dist cap on it causing a miss.
Most of this seems like pretty strait forward neglect by owner and a good weekends worth of work. Does this seems like a good deal to anyone else or am I off my rocker? If I get it, my buddy can do the labor for cheap so I'm looking at around $1500 parts and labor with a total investment of about $7 for a 91 with 89,XXX on it.
Thanks again, advice on the clunk made for a quick diagnosis.
