92 3fe P/S input seal question
Arizona
Is it possible to just replace the input seal to my power steering gear box on my 92 3FE? I've heard from the 60 guys that you can do it w/o even removing the box. Is it possible on the early 80. And can you source just eh input seal and not a whole seal kit?
Second how much Lucas Stop leak should I run before I give up a accept that it isnt going to stop my leak. I've been running it for about 500 miles.
Couldn't hurt. You'll prolly have to pull the box, kinda tight in there. I think the full rebuild kit for the gear box is $150-ishfrom the stealership, I'm sure you can buy the specific seal you need, but IMHO if you have the gear box out of the truck and torn apart, might as well re-build the sucker and replace all the seals. I am getting ready to do the same with mine cuz I'm tired of re-filling my rez and leaving PS stains everywhere I go.:grinpimp:
Or, post up in the wanted section or hit the junk yards. A good used box will cost you $500-600 and i've seen re-builds go for up to $1000.
A new box from Toyota is like $2600:meh:
Wow, I got a '94 box off ebay last year for $40. From one of Proffitts take offs a swap.
It hasn't been installed yet, I got sick this year.
As far as Lucas is concerned, are you using PS stop leak or ATF stop leak?
PS stop leak
hmm, i wonder if ATF stop leak would work better, afterall that should be the fluid you are using. If you ain't using ATF fluid then that is your problem.
Should I dry and drain the resevior and fill it with ATF. Can I run Lucas ATF stop leak in my resevoir?
If you ain't got ATF in your PS system then I'd drain the crap out of it and put ATF in it, yes. I'd leave any stop leak out of it until you can get the correct fluid in it for a while. That may stop your leak. These systems were not designed for power steering fluid.
Ok Ill try the ATF But is it possible to just change the input seal if necessay?
How much of the fluid can I get out by just using a turkey baster and taking fluid out of the resevior? And can I mix ATF with PS fluid?
I wouldn't. I think you can put your axle on stands and turn the steering wheel back and forth with a line pulled and get everything out, don't qoute me though. Maybe get a few quarts of ATF and flush, flush, flush.
