I know there are multiple threads out here for how to adjust your MAF...but I cant find the ones that indicate whether I should adjust CW or CCW to increase HP. Can anyone advise me correctly???
Thanks!
Thanks!
how many clicks did you move it and are you sure it wiped off and is not just hidden behind the arm? If the mark is gone I'm not sure you will be able to determine where it was originally, but you can turn it clockwise until the idle smooths back out.
Honestly, I was counting on the mark being there to return to baseline, so I was moving it back and forth...so I dont know exactly how many of which direction I was at when I moved it.
3/4 to a full turn???
No no no...not the gear 3/4 to 1 turn...the screw that holds down the spring lock.DB was asking if I loosened it so much that it allowed the gear to free spin.
I only loosened the tightening screw 3/4 to 1 turn. The gear/spring was still very much under tension.
<snip> "black smoke out of the tailpipe" would indicate a very rich mixture.
Could it be that Im still running too rich, although there is no black smoke?
