- Location
- United States
Pulled this engine plus everthing else I could get my hands on out of a 92 model year SC 400 for a conversion, but never got around to it. Here is what I have for sale.
*1UZ-FE, rear sump, mileage unknown, it did run when I pulled it
Compression in all cylinders is between 175-180 PSI ( I boroscoped the cylinders and you can still see 75-80% of the cross hatching on the cylinders)
*All accessories(AC pump, pwr steering, alternator, starter,flywheel)
*All engine covers
*1UZ auto bellhousing
*Mass air meter and air intake ducting (no air cleaner box)
*exhaust manifolds
*Engine ECU
*Cooling fans and ECU
*Fuel pump module
*Fuel pump two speed controler
*Uncut engine harness (infact I have most of the harness out of the car, which includes to the F/Pump and etc.
*Throttle cable and pedal
*Cruise actuator and ECU
*Transmission sensors and wiring
Everything you will need for a conversion. Engine is clean inside with NO sludge,cam bearings are in great shape with no scoring.
Located in Cincinnati OH,
Asking $550.00[/B][/SIZE][/FONT]
Email me at Swampymarsh@fuse.net for more info and pic's
*All engine covers
*exhaust manifolds
*Engine ECU
*Fuel pump module
