Hi,
I'm sure there are other threads on this, but i looked some and couldn't find exactly what I was looking for. if there is answers in other threads to this please kindly point me to them...still a bit new to this, but you guys nailed my last problem with the cracked intake tube. My powersteering pump leaks and as a result of neglecting it. It leaked onto the AC compressor and the clutch plates came apart. Now the AC pops the fuses since it locks up when trying to engage the clutch. So I obviously have two problems. My first question is what is the best remedy for the PS pump? Rebuild? Replace - with OEM or aftermarket? If aftermarket what is the best brand. I have heard these pumps are notorious for leaking. Any other typical LC issues related to the PS pump or lines? Once I fix that I will have to tackle the AC. I spoke with the mechanics shop today where I just got the LC smogged (passed!) and they gave me a rough estimate of 1000 to 1400 to fix the AC and convert it to the new R34 or whatever the latest gen freon is. Were they correct in telling me that you have to change the whole compressor and you cant just change the clutch / discs? If that is the case any recommendations for the brand. Does everyone agree with switching to the new freon? Would you guys just pay the mechanic for the AC or do it yourself? Or as much as one could change the pump and put in the oil? Then maybe take it into the shop to clear the lines and replace the O-rings and charge the system. Well thanks again in advance. The LC is stock.
Eli
Eli
