91 LC dies when under load
Hey all,
Ive done a lot of reading here and got a number of problems worked out on my LC, but Im not sure where to go now with this.
Initially, I was having a hard start and no idle situation. Turns out, the previous owner had taken the top off of the air flow meter and not sealed it back well. Fixed that, adjusted the TPS according to the service manual and plugged the unplugged O2 sensor back in. It will now start fine and idles as well. It idles a little rough but idles at about 800 RPM, right where it should be if my info is correct.
Right now, the only engine code is 21, for the other O2 sensor.
The issue is that as soon as I put any load on the engine, it dies. As soon as I put it in gear, it dies. Even if I turn the blower on, it drops the RPMs down substantially and almost dies.
I checked for vacuum leaks with a propane torch and didnt find anything. And tested the fuel pressure with a gauge I rented from the parts store, and it tested fine according to the SM.
Im not sure which direction to go with it at this point.
Any thoughts?
Thanks!
Maybe check your rubber intake tube for cracks?
"Turns out, the previous owner had taken the top off of the air flow meter and not sealed it back well. Fixed that"
Did you test the AFM per specs? If not, that is likely your problem or what Alleycats said.
I can sure check again. I put the propane torch under the intake hose and didnt get any chnge of rpm, but I can check that again.
I did check the AFM. It tested out fine. I went ahed and cleaned it out just to make sure the door moved smoothly and seated properly.
I will say, when I pulled it off the first time, 4 washers and 4 thick 'spacers' fell out of the main chamber. I have no idea why he would have put them in there, but Im pretty sure they didnt belong in there.
Since the previous owner got into the AFM, the 2 screws on the outside were removed and damage was done. You need to check the specs of the AFM operation. As far as the propane check, I would just carefully remove the intake hoses and check for cracks.
Here's the manual to check for the specs of the AFM: http://tlc.cnlson.com/3FE REPAIR MANUAL.pdf
Takes about 5 minutes to load.
Just read your post.
The washers/spacers are meant to be there.
What about a egg issue with erg valve. Not sure it this would occur under these circumstances but I remember testing my ear valve and it would stall out the engine on some of the tests. Just a wild guess.
What is the purpose of the wshers and spacers? Everything seemed operate fine on the afm without them. Everything tested within the ranges specified by the service manual.
As I recall, the spacers center the AFM through a gasket onto the air cleaner housing. Since they are upstream, not having them shouldn't affect your stalling issue.
Finakky had the time to check out a few more things. Rechecked the AFM and the intake hose but there are no issues there. There were a couple of iffy vacuum hoses, so I replaced them. Still no change on the issue. Starts, idles but dies with any load, even the heater blower.
I could really use some other ideas!
Thanks
I would go w/ Summit Cruisers comments regarding the AFM. If the AFM was opened in the past, I wonder if the previous owner had to fix it/weld the connections back together and now it is acting up again. When it was opened did you notice if it had been soldered at the connections? I have seen/heard of trucks that have had the AFM repaired and then it would act up causing all kinds of idle and stalling issues. Can you borrow someone's AFM and swap it out. If so, make sure you remove it properly on both trucks as to not damage it.
The previous owner admited he had pulled a wire off and removed the top to solder it back on. You guys think it coukd be bad even though it tests within spec?
If so, I'll have to buy one to test it. I dont know anyone around to borrow one from.
Have you tried your local Land Cruiser clubhouse?https://forum.ih8mud.com/categories/clubhouses.144/
Not sure where you are located. If you're in Oklahoma, I have one you can test with.
Update: finally got a hold of another AFM of off a running vehicle. Changed it out and it made absolutely no difference, still dies as soon as I put it in gear or turn on the blower or even turn the steering wheel.
On a positive note, I have a used AFM if anyone need one..........
Thanks
I had some of the same issues with my 91. Changed AFM, fuel pressure regulator, fuel filter, fuel damper and 02 sensor. Still had hard start when warm issues and no power! Changed fuel pump and bammmmm! Runs like new. My fuel pressure checked out too prior to change. U can access fuel pump under 2nd row seats and carpet.
