Hi everyone, I would like to formally introduce myself and my land cruiser. I graduated high school then became a mechanic/tow truck driver for AAA in san luis obispo, CA so that I could afford my 4x4 hobbies. After 2 years I joined the Navy to become a nuclear engineer on submarines, they sent me to charleston, SC for school. I have been here for just over 2 years now. I'm getting sent out to Hawaii sometime in january and from what Ive been told its easier to get a vehicle registered there that is stock looking than one that has aftermarket parts on it. So i'm saving up parts to put them on when i get there. I bought my first lc 3 months ago, it ended up having much more rust than I had seen upon initial inspection. It has the 3fe and 175k miles, I'll list up what I've done to it so far. Although most of it has been preventative maintenance.
When i bought it there was a misfire so i did all of the normal tune up stuff. Plugs, cap, rotor, wires, adjusted valves, set timing and i still had a miss. I thought it was an electrical issue which turned out to be a bad timing light that i was using. Long story short the gas tank had a rust hole in it so i replaced tank, filter and tested the injectors. I found the injectors were clogged and sticking open/closed so i replaced them as well which fixed my issue.
The speedo didn't work so I ordered one from somewhere in Australia and that fixed it.
I wanted axles that were less rusty and I also wanted better brakes so I bought some 96 lc axles and swapped them in. I ran into a few issues while swapping them over. The first was when taking out the rear axle I wasn't paying enough attention and lifted the lc while the lspv got caught onto something on the axle. This did something bad to the inside of the lspv to make it not work. While swapping rear axles I was prying the axle sideways to line up the track bar bolt and put my finger into the bolt hole to see how much harder i had to pry... the pry bar slipped and it cut off the tip of my index finger. Once I got the front axle off I realized that the brake lines weren't the same, the newer lc's have a brake line for each front tire, mine had one. Easy fix though, I just swapped the axle brake lines and it works great. There was an improvement in braking from the axle swap just FYI.
I completely desmogged it while I was trying to diagnose it and since I had the upper IM off it made installing the air injector plugs much easier. Removed the air injection pump (looking for a york compressor), block off plate for the egr, removed all of the vacuum lines and little solenoids around driver fender.
I removed the flares, covered the holes with aluminum tape and sprayed with some off brand bedliner in a can. I wanted to monstaliner it but i got too impatient and just did it one night.
I took off the front/rear bumpers and threw them away before I realized that my wife wasn't going to let me buy new ones yet.
I bought a snorkel from my sister at low range off road to see what kind of discount she could get me.
Installed double din head unit and revamped the stereo system.
Since I installed newer axles I needed at least 16" wheels. I scored some 17" takeoffs from a 2015 4runner. I plan on going to 37's in the near future so I also picked up some cheap little rollers off cl and had them mounted.
I am trying to get rid of all the exhaust leaks so I ordered new pipes from the exhaust manifold to the back of the cats and now I'm just waiting on the y that flanges to the back of the cats then the exhaust will be done.
I drove up to the Southeast Overland shop (real nice guys in there) and picked up some lifetime led low beams. I had to readjust my headlights so they weren't blinding everybody. Overall I would give them a 7/10 due to the fact that the light beam isn't consistent, some spots are brighter than others. The lights are much brighter than factory though.
I made a "diaper" for it. The shipping company said that they won't ship it if it leaks, so i cut up some thin sheet metal and bolted it between the oil pan and tranny pan with some absorbent towels. It has a rear main seal leak and I just don't have the time right now to replace it. Changing the diaper is a much easier temporary fix.
Ever since i messed up the lspv the rear brakes haven't worked... so I deleted it. I went to auto zone and bought a female female m10x1.0 and bypassed the lspv. I ripped out the return line that goes into the T at the front and bent the brake line to go just straight from mc to front axle. My brakes are very basic now, there are 2 ports on the mc, one goes to the rear the other goes to the front. They work fabulously also. The only part needed was $1.61
Things that I still need to address are:
The cruise control isn't working, the light comes on but doesn't do anything. I have seen the diagnosis manual on here before i just need to find it again.
Tranny cooler lines are very rusty and look like they're gonna pop at any moment.
Rear main seal or possibly pan gasket?
My bank account, I want too many things that I can't have.
That is all that I can think of. I will post up some pics from my phone in a few minutes.
Steven
Steven
