91 FJ80 alternator issues
Santa Rosa, CA
I've spent all weekend trying to nail down the charging issues with my 80. after taking the alternator out, testing it at the local auto parts store, it checked out OK, reinstalling it, double checking all connections, fuses and relays with no progress. I removed the alternator again, positive that the guy who tested it originally missed something, and took it back to the store and had it rechecked-OK again, getting pissed I took it home and put it back in. This time I ran all the checks but revved the engine with the voltmeter on the battery, hey! voltage!!, narrowed it down to the voltage regulator, which I suspected from the beginning (grounding terminal F increased voltage) find and purchase voltage regulator. get home and disassemble alternator the voltage regulator is soldered in and the one I bought bolts in. What to do? The alternator is a Bosch rebuilt OEM Denso alternator, which I imagine is a good one nobody carries a solder in voltage regulator, do I scrap it and drop 250+ on a new one at the dealer? Any suggestions or tips would be greatly appreciated. The voltage regulator is a TRANSPO IN 235 12v 259
I'm only going to say this once.
Bosch BLOWS. I went through 5 alternators over a few years, all Bosch aftermarket, before I finally saw the light and went OEM. No problems for almost two years this September.
Last year i changed the regulator in '91 FJ80 (80 Amp version), it was definitely the same type (TR235) and it was soldered. 80 and 90A alt's use different components, maybe it's the source of problem; can you post part # from small sticker on alternator's body?
