...or indicate such bad rod as earlier stated :-O
Dweezil said:Well I pulled the valve cover yesterday and no broke valves spring etc,just a little bit sluggy.It looks like it's not oiling to well.You can turn it over and run it for a second and not much oil seems to come out.
Dweezil said:I put some decarbon spray in the plug hole last night and when I came out this mourning I noticed the piston was at the top.I stuck a long screwdriver in and pushed the piston down by hand!! I guess I do have a broke rod.You would think something like that would make a LOT of racket.
It looks like you can pull the pan pretty easy.I guess I'll look at the damage and go from there.
Has anyone ever pulled a piston from the bottom?
Dweezil said:What usually makes the piston break?Does this mean the rest are subject to break as well?I know a rebuild would be best.But since it has only 155,000 on it, would it be safe to patch it with a new piston and rings.
Tools R Us said:It's rare but they do fatigue crack, the others may not be affected. The only way to tell is pull them all out and clean them up. if you want to reuse the same parts mark everything so they can go back in the same place. If you don't want to rebuild, do what we call a ring and bearing job. Source a used piston, Steve from Man-A-Fre is doing a motor and may have one? Get a cheap set of rings, no moly or trick stuff, a set of rod bearings, pan, head, valve cover and exhaust gaskets. Pull the pan, head and pistons, hone the cylinders so the new rings will break-in and reassemble.
Dweezil said:I can't get my oil pan off! I fell like a tool.I have tried all the methods I know (except for driving a screwdriver and prying it) and it won't budge.What's the trick?I don't want to destroy my pan.
Dweezil said:Has anyone ever pulled a piston from the bottom?
