91 alternator issue
Chesterfield, Va
Good evening. I am looking for some assistance or a diagram for the alternator on a 91 FJ80. I have a lot of play in the belt and am unable to get the slack out. I thought I had all the bolts loosened, but, as I broke the long adjustment bolt trying to get it tightened. I have the FSM but can't get a clear idea as to what is what. Any assistance, photos or diagrams would be greatly appreciated! Also. Does anyone have a part number for the adjustment bolt I snapped?
The alternator bolt needs to be loosened before the adjustment bolt (access drivers top front). @Photoman got it right. Then the long 14mm head bolt needs to be loosened from underneath in order to allow the alternator to easily pivot. Here's the manual I use. Takes about 5 minutes to load. (Edit) Just realized you have the FSM.
http://tlc.cnlson.com/3FE REPAIR MANUAL.pdf
Loosen the upper bolt in the picture that goes through the alternator ear. This locks down the adjustment and should take a 12mm wrench. Loosen the bottom mount bolt under the alternator. This should be a 14mm. Then use the long adjustment bolt to tension the alternator belt. The other belt may then need to be adjusted from the power steering. It has an idler and pump adjustment. Lock the bolts back down after adjustment.
Great pic. That helps. I was having trouble seeing around the air pump. Haven't gotten pissed enough to remove it yet. Any ideas on how to score a new adjusting bolt? Mine is now in 2 pieces.
