91 80 series center diff issue.
Sylvester Georgia
Hey guys, long time lurker, new owner.
I just brought home a 91 80, and it has a few issues keeping it from the road.
First and biggest problem I see aside from a laundry list of maintanence items is:
The truck will only move when the center diff button is engaged. When it’s disengaged and you put it in to gear there is a terrible grinding noise. It’s obviously not catching. The speed of the grinding is slower in 4 lo than 4 hi which makes sense .
I have driven it on loose dirt in figure 8s trying to disengage cdl , and no luck.
I also jacked the front of the truck up and was able to turn both front wheels, so does this mean cdl is not locked ?
I’ve read through tons of threads and have not found this issue yet.
Thanks for the help!
It means your front drive flanges are stripped.
The six bolt star pattern covers on the front hubs are splined and are what drive the wheels. If they are stripped, the center differential just spins, the front driveshaft turns, but you don't go anywhere.
You need the early drive flanges.
Get with Kurt at Cruiser Outfitters @cruiseroutfit and he can get you hooked up.
Thank you!
