91 3FE FJ80 code 71 update! All fixed!
Inland Empire
Hey ya'll,
working on clearing my code 71. Been reading so much on the site, and have learned so much. So far, have removed and cleaned my EGR valve. Vacuum checked and it works well. Have checked vacuum lines (lines to modulator, back pressure hose, lines to throttle body), all good. Vacuum tested hose from vacuum modulator, and thats good too. My question now, does the 3fe use a vsv for the egr? After countless google searches and ih8mud searches (3fe vsv/91 fj80 egr vsv) I only encounter posts about fzj80 vsv's. Checking the vacuum hose diagram under the hood, it would seem that the 3fe does use a vsv. I actually traced a hose from the vacuum modulator over to one the 3 vsv's (I'm guessing they're vsv's) sitting on the driver wheel well. (the one in the middle IIRC) If I am correct, then that should be the EGR VSV right? I am planning on using the Dorman Dodge vsv transplant to replace it if is fried.
*updated see below
So as an update, VSV is good. EGR is good. Bought a Dorman 911-609 egr vacuum modulator that is an exact match to the OEM Toyota for $23.35 on amazon.
Dorman 911-609 EGR Vacuum Modulator Amazon product ASIN B0083H5RDM
Now the problem is that I am getting very low vacuum from Port Q on the modulator. This was the same with the original oem installed. I have great vacuum coming from port R when I rev the engine. No vacuum what so ever from port P.
I noticed that on the throttle body of the 3FE there are 2 ports. One marked E, the other marked RP. From my understanding of the vacuum hose diagram under the hood, port E goes to the EGR valve correct?
So after researching so much from this site, I have finally defeated the code 71 I’ve had on the cruiser. So satisfying to see vacuum at all the required ports, and much more satisfying to see the CEL disappear on its on.
Here’s a run through of all the steps I did.
(I know other threads have gone through this process extensively but I figured a little more info wouldn’t hurt.)
1) So I started with the egr valve itself. With a vacuum pump, I applied vacuum to the line going TO the EGR valve itself, while the cruiser was at idle. Engine would choke and stumble. Which is a good sign that the EGR is working. To go further, I removed the valve, and soaked it in throttle body cleaner for about 5 hrs. While it was off the cruiser, I applied vacuum again while pinching off the outlets to watch it hold vacuum. So I discovered the EGR wasn’t the culprit.
2) moved onto the vacuum modulator. Attached my pressure gauge to port Q on the modulator and revved the engine; noticed no vacuum there. As mentioned in the above post, I bought a new modulator just to have a new modulator. I’m positive that the stock one still works but at least I have a back up one. Unless anyone else needs one.
3) still no vacuum at port Q. So then I checked port P and R. R was good, P was the problem. So I replace the vacuum lines from the throttle body to the hard lines, and the hard lines to the modulator. Still no vacuum.
4) while I was at it, I checked the EGR VSV, (which is the middle VSV of the 3 in the engine compartment on the driver’s side). Unplugged it, and applied 12V to it and listened for a click. That checked out. Confirmed that the VSV was engaging. Also, applied vacuum then applied 12V to watch it hold vacuum and release when I engaged it.
5) still no vacuum at port P of the modulator. So then I applied vacuum to the line that plugs INTO port P. Noticed that vacuum pressure would hold there. Indicating that there was an occlusion. (If there was no occlusion, there shouldn’t be any pressure building up) also tried applying vacuum to the other side where the line from the throttle body to the hard line goes. Confirmed blockage.
6) I attached a clear silicone hose to the hard line from the throttle body side, and sprayed Throttle body cleaner down the hose. (A liberal amount) and then attached the silicone hose to an air compressor. Remove the corresponding line on the other end that plugs into the modulator. 3 squeezes of 100psi and I see a black ball of dust shoot out and impact the engine compartment like a paint ball.
(Give the other vacuum lines the same treatment while you’re at it.)
And that’s it. Now, everything is running how it should be.
Thanks for all the great info from all the contributing members here on this site. As a relative newbie to TLC’s, I can attest to the vast knowledge and information that abounds this site. I know I didn’t reinvent the wheel or anything with this info that I provided, but I had a great time trying and learning everything I’ve read here. So I hope I can return the favor.
