91 3FE fast idle adjustment
Lawrence, Ks
Hello all, I've searched the archives but have been unable to source a cause of my issue. I've had a 1100-1400 idle RPM since I purchased this FJ80 about two months ago. When I purchaesd it the O2's were gone as well as exhaust they attach to. This weekend I finally repaired thatssue with mixed results. No CEL, better acceleration however idle issue persists. I've inspected for vacuum problems, checked cable adjustments, ar intake system to no avail. Any ideas? Thanks in advance.
Even though you checked, this problem almost always ends up being a cable/open throttle issue. First try manually closing the throttle under the hood, and if necessary try again with the cables disconnected. Then make sure the bumpstop isn't preventing the throttle from closing.
If the throttle and TPS check out, have a look at the Idle Speed Control valve (the dealio in front of the throttle body) and the wiring to it. The two times I've had high idle issues, it has been a poor connection at the TPS and an open wire to the ISC valve.
Finally got around to more fre time with fj and while replacingVC gasket,I discovered air intake hose coming directly out of air filter housing cracked. I'm going to replace that to see if it has any impact. Thanks again for the heads up!
After living with this nonsense for 4 years now I'm back to it. I replaced all intake hoses and it seems to really seems to climb with ac on. I understand it has a throttle solenoid to but idle with ac on but this is crazy. Close to 2k at idle. Really scratching my head here. No codes stored.
Make sure your tps is adjusted properly. If you have the extra time and funds looking into a full tune up and valve adjustment. Start ruling everything out. You make have a vacuum leak at the intake plenum it’s self also. If you have an exhaust leak pre o2 sensor this can cause you fluctuate or have a high idle because it will get oxygen where it shouldn’t and the o2 sensors with see it and report back to your Ecu and cause it to trim fuel. The fault isolation it somewhat difficult in the aspect of almost everything can cause a high idle for you. I’m also battling the same problem and have trouble shot it down to a tps. I need to do the finishing touches but will no more in a few hours.
It was 1900. But I after a new tps and it properly adjusted and finding on last vacuum leak with properly adjusted valves it runs like new.
