Ok this started on expeditionportal.com and I have posted it on a few other forums also trying to get more folks on board...
so here I am on mud seeing what kind of interest there is in a weekly ham radio net where new folks can practice & get to know their radio and talk offroad stuff at the same time....instead of the pure ham stuff that is usually on the air.
Here is the post from the other forums and please know all thoughts are welcome
Ok everyone let's give the Offroaders Ham Net another go....
The topic is up for suggestions...navigation, tires, auto vs manual trans, getting better gas mileage.....
I have a BBQ with a bunch of my 4x4 friends this Sat from 4pm on but I am not 100% sure I will have radio range out at the host house.
Therefore I would like to start the net around 3pm when I am at my place and try to keep on the air all the way to his house....
This is a different time than we have tried before so maybe we will get more folks...use it as an excuse to get out in your rig for an afternoon jaunt...
In a perfect world not only would I have radio range but we could then show off the cool things ham radio can do....
However if it looks like no one will be on air...then there are other times we can go for...
later sat pm since it is hot everywhere and maybe after the sun sets is a better time..
sunday pm since that has been a time we have used before...
please let me know when you can get on the air
so if you are new to this idea here is a quick rundown of how we are doing this net & why
the why:
we are using irlp since it gives us a "clean" area of air that we can talk offroad topics and not just ham radio stuff and usually without "regular" hams hearing all our newbie mistakes
the how:
first get out your radio owners manual and figure out how to use repeaters and how to manually generate dtmf tones
there are only 2 numbers you will need to know
the irlp node you are trying to hit...in this case we are using the western reflectors odd channels starting with 1 and going up till be get a clear one..so start with 9251 and listen for offroaders chatter
the other number you will need to know is "73" that is to disconnect your node from the western repeater or any other node
now go to irlp.net and on the left click on "node info"
first click on "Connected Nodes and Reflector status " and check out the western reflector see everyone connected to it...see which channels are free?
then look for "List of nodes and Frequencies" and click on it, look for a node near you...or lots of them...look for 1 that is "idle" which means it is not being used...
now after you plug that nodes repeater info into your radio then key your mic and say "this is ?????? attempting to connect to the western reflector" and WHILE YOU ARE HOLDING THE MIC OPEN type in 9250...you should get an auto message & hear lots of chatter since you are now connected to lots of folks..now some repeaters won't let you on the main channel of a reflector but will let you on another channel...so if you get an error message try 9251
if you are successful then make sure you finish up with "this is ?????? disconnecting from the western reflector" and WHILE HOLDING YOUR MIC OPEN" type 73...that will disconnect you
If you have net access during all this you can actually see it happen live by refreshing the webpages mentioned above.
If you have questions please post'em up...if you would like to try this before the net and would like me on air to chat then post up your free times to try...
thanks everyone and looking forward to a great net
the why:
the how:
