9/73 Transfercase question
NJ
Hey all,
My 9/73 transfer case is currently not switching over to 4wd. I took it out and it looks like the fork at the top of the case won't move the rod(??) to put it into 4wd. It seems like a rebuild is in need; to my question:
In 9/73 they switched transfer cases. How can I tell which transfer case I have so I can order a rebuild kit.
Thanks in advance,
Judge
Hey all,
Thanks in advance,
Judge
Not sure what you mean they switched cases?
Toyota switched from a 3 to a 4 speed
I called Georg @ Valley hybrids, he set me straight. thanks
Your 9/73 has four speed? The 74 model year started with a three speed then switched to a four speed. Not really clear when the change over took place in the US. Can find listing for three speed transfer cases well into 74. Just simple a matter do you have a three speed or four speed. If four speed it can get trickier. Two styles of shifter were used on the one piece transfer case. So 9/73 would have to consider did a four speed replace a three speed. Then shifter and gearing in the transfer case could be a couple different kinds.
