When you checked the AFM, did you check the voltage smoothly changed throughout the motion of the flapper? It basically provides a voltage that is proportional to the amount the flapper is opened up by the air going into the engine. If it has a dead spot the ECM may think the engine is still at idle.
Now, for that signal. AFM/Vacuum. What happens if the vacuum is at zero or goes to zero when you apply throttle? What could not properly be switched on/off, or switch on/off that is required for smooth operation?
