88 jeep help
indiana
I could use some help if you dont mind .. i just got an 88 jeep wrangler Laredo got a Weber 38 conversion in stock state . i need components come stock on the carb in close to sea level i googled it it said 300m/984ft this is our altitude close to sea level i might just need the regulator or needle and seat.
recommended starting points on your idle and mixture screws. im so lost its not even funny..
Start off by doing a fuel pressure check. Look up the fuel pressure specs for the Weber and see if your current fuel pressure is within those specs, if not get a good fuel pressure regulator and go from there.
