87 hj60 fuel line ?
Phoenix
currently finishing up a frame swap and labeled practically everything but missed these lines off the gas tank. some are obvious due to size but where do the others go?
Probably dumb question but Are they important? I'm guessing emissions of some sort.
And the one nipple has snapped off ideas on how to fix?
Thanks! At least now I know what it is sadly that pipe is shot and it looks like it's time for a reel of new hose and some fun :/
If that broken bit is the U just leave it or make a chewinggum connection, the thing has no use other than when you roll on the roof it does not drain the tank fast.
If you put a small piece of rubber hose in a circle is has the same effect, I think you must keep it above the tank or as high as possible.
Sorry those small pictures upside down reverse mathematical thinking is to much trouble for me :beer:
file.php
Lol chewing gum fix and pray I don't roll, because if I do I will probably self combust into flames lol sounds awesome :hillbilly:
But really now probably just a little job weld around the outer wall and new hose. Then call it a day?
I dont see what is broken off at the fuel pack (please explain before you explode because it is another hose and not the U)
FILLER small - small - big - small- small
rusted U .........................U.....................
The one small above the big is for the U tube (lololo, man :bounce2: :bounce: :rimshot: link to fuel tank hoses: click here to solve headache
Then click here to finish it off:
Some pictures, found the original of the hoses, make sure all the hoses are clamped correctly and tight.
When I filled with a truck fast filler it started leaking somewhere but that is also because vwo makes the rubber soft.
file.php
file.php
file.php
file.php
