84-HJ45 longbed
Seattle
I'm doing a major repaint.
Where to buy all replacement cab and window gaskets?
Who around Seattle is best to bend/shape replacement front compound corners for the removable steel hardtop?
Don
For the seals I would look at Cruiser Corps, maybe CCOT (prices are usually good, but make sure you buy OEM and not their aftermarket), or some of the OEM Toyota guys on here (@cruiserdan and @beno come to mind). For the body work that might be more challenging. @torfab is our local Seattle cruiser shop/guru so I would reach out to them. They should be able to help or point you in the right direction.
For the seals I would look at Cruiser Corps, maybe CCOT (prices are usually good, but make sure you buy OEM and not their aftermarket), or some of the OEM Toyota guys on here (CDan and Beno come to mind). For the body work that might be more challenging. @torfab is our local cruiser shop/guru in Seattle so they might be able to steer you in the right direction on that one.
How do I contact either CDan or Beno?
I got my seals from SOR. They are pricey but you get OEM. CDan or Beno (look in the vendors or members section of this website for contacts) may be able to OEM if it is still available. I tried the CCOT door window rubber and seals and I ended up not using it and then buying again from SOR for the real deal.
I made my own compound corners for the roof and welded them in. I doubt you could buy a new steel roof, but I recall that someone is/was making a fiberglass reproduction.
