8274 oil
890man
Thousand Oaks, Ca.
I have an older 8274 waiting for me to make a bumper for it. I have been storing it upright but it fell on its side without me knowing until I saw a lot of oil all around it. I looked in the tech section about rebuilding the winch but I didnt see anything about what oil and how much and search pulls everything with an 8274:crybaby: Before I call warn I thought I give it to you guys. Where would the oil leak from? Should I rebuild? I havn't been into the winch before. I will pull it out this week and take a closer look but any help would be great.
Thanks, I'll pull it out tomorrow. I feel kinda dumb not seeing a fill plug but I never used one (had a 8000 on my last LC) Should I be concerned about why the oil leaked out? If it can get out, water can get in.
BTW, I looked on the manual for the 8274-50 and under maintenance it says: "No lubrication is required fo the life of the winch, unless the winch is submerged in water. If this occurs, a qualified service center must complete service as soon as possible to prevent corrosion damage. If the control pack is submerged, it must be replaced when the winch is serviced."
No river crossings for anyone with a 8274-50:flipoff2:
non detergent 30wt fill to top of fill plug like a diff
Fill plug? I don't think so. I had mine apart last spring and don't remember a fill plug. The fluid was badly contaminated and there wasn't much of it. I didn't have any of the non-detergent 30 wt and so used 80w-90 gear oil. It seems to be OK. I should have tapped a hole for a drain plug and a fill plug.
No fill plug. Top cover is the fill/ empty. I had one with a leakng seal and I believe what was coming out looked like auto transmission fluid. pretty thin. To stop the leak without replacing the seals I used STP, shows how old I am. Worked great, kept it in for a few years then rebuilt with new seals and put 30 weight oil in ONly down side to using thicker lub is if you are in a colder climate, might cause a little drag. I wonder if compressor oil would work?
Thanks guys, sounds like 30 wt @ 6oz. I'll tear into it sometime this week. I don't know that I will do a complete tear down but I may rethink that, it is out of the truck right now and once its on I will never want to take it back off.
