8274 brake problem, pb know apparently
France
Website
www.serie4.fr
WARN 8274 brake problem, pb know apparently
hi
i've reconditionned a warn winch 8274,before i reassembly all the parts i read a lot a often a problem came back often for the use of this winch.
under heavy load, the clips who retain the brake assembly jump out and all the brake with the nice beraing balls fall in the mud..nice no ?
i've remount all the winch with the hope not to have this problem but no luck for me...clips jump ou, and bearing balls too... fu.k !
itake a look on many forum and find this, if you have other solutions
i take them !
dunkane AT serie-4.fr
here is what i found
http://forums.lr4x4.com/index.php?showtopic=1522
and here
http://members.shaw.ca/red90/8274_brake/8274_brake.html
i put a letter of a man named D90SV, who make some mod for competitor with 8274 from warn., here are the explanation of the mod on this winch.
Hello Dunkane,
Yes, we do a make an upgraded mainshaft for the 8274.
The new mainshaft does away with 5 problems.
1/ The material grade is changed from EN24 to EN36, so that material failure is
a thing of the past.
2/ The original shaft has groove machined near the end (This is where most
mainshafts break) the new shaft does away with this and uses a different way of
retaining the mainshaft inside the housing.
3/ The new shaft comes with a shim kit, this kit holds the gears in the correct
place (Unlike the orginal which allows the gears to move) this stops premature
damage and breakage of gears and teeth.
4/ The new shaft does not use a circlip to retain the brake on the shaft, but
uses a bolt on cap, thus solving the problem with having to pick ball bearing
out of the mud.
5/ The final problem we solve is at the other end of the mainshaft, we make the
end that fits inside the roller bearing the correct size, unlike Warn, who make
it to small putting pressure on the bearing.
The shaft that you have found pictures of, is actually a very early prototype
that we used and still uses the circlip to retain the brake.
We also do replacement brake shoes, solenoids and drums (Reduced diameter and
lengthened to your spec).
We are currently developing a 'Free spooling drum' which will be amazing when
finished (Approx 1 month?)
Mainshaft kit £220+vat
Brake shoe kit £20+vat
Solenoids £70+vat
Drums from £160+vat
These are retail prices
Not cheap, but the best, and can not be beaten.
Hope this is some help
If you require further help please do not hesitate to ask.
Regards
Jim (D9OSV)
################################################3
apparently warn US answer me this :
"In 1998 we did make improvements to the 8274 brake assembly. We are now
using a new type of retaining ring and also wave washers behind the
retaining ring to keep tension on it. Since this improvement was made I
have not heard of this issue occurring.
My first 8274 was a pre 1998 version, and the retaining ring popped off
on me, a scary experience. I now run a 1998 version 8274 and have not
had any issues since. If you purchased a new brake assembly part number
7634 it will be the improved design."
here is what it seems to be a answer..but i'm not very sure...
wave washer on 8274 after 1998
Desertdave said:
I've rebuilt two 8274 winches since 1998, and have used the modern parts (wave washers) from Warn, with no brake issues on either winch.
Hope this helps.
could you measure the lenght of the wave washer diameter ?, from the beginineg of the axle ?
and send me a picture of the way to put the wave washer... :)
best regards
Dunkane
webmaster of WWW.SERIE4.fr
TLC SERIE-4 FRANCE ASSOCIATION
There is another 8274 rebuild on the Pirate4x4.com site. I am away on vaction from my links... anyone?
Rezarf <><
mr_manny said:
in fact what i need to know a picture of the new shaft from Warn..wave washers behind the retaining ring are on a littler diameter, and on certain length..would like ton know them...and how this wave washer are positionned too... :)
i'll put a complete restauration more complete than billavista on the 8274 unit soon
www.serie4.fr
TLC Serie-4 France Association
best regards to all of you guys
new 8274 brake shaft picture
here are the picture of a new style brake shaft , note the method to put the "cam" on the shaft....before it was only one piece, now it's two...note also the little difference at the end of the shaft, where now you have to put 3 little curved plates, to compensate the deplacement of the brake and limit the effort on circlips
sorry for my basic english guys !, my french is better :)
i'll join later in this discussion cad dxf of the brake shaft with cam profile...note the part have a very high hardened treatment (i tried to make a thread at the end of the shaft, i had to use a special cutting tool and electroerosion to make the M10 thread, to prevent expulsion of the brake under very heavy load)
seems there is a new problem on this Fu..ing winch....the bronze bushing go out of his home...pushing by the cam system..warn france don't know why (sure they only sells.,fu..ing reseller :)
if someone know the fix...
Clean up the bore and locktite the bushing in place....Use green locktite if you can find it....it is a bearing/bushing retaining compound.
I have not had one spit out of a bore after using the green locktite.
Good luck!
-Steve
8274 new SHAFT DXF
here is the jpeg of the brake axle shaft of the new 8274 warn
sorry cant' upload DFX file here on this forum.
Okay, Ithink this is the most appropriate thread,
I am in the process of rebuilding my brake right now. I got the updated version of the brake in the rebuild kit. and a new ratchet doing away with the pucks.
I put everything back together last night and it seemed real loose. Like I did not have to fight as much to get the snap ring back on the end. and when back together I could see the new friction material through both sides of the inner and outer brake part?
I understand the new shaft uses the three convex washers, but my old shaft does not have them, and they wont even fit around the old shaft.
What I have done.
Put in the new brass washer. I Need to locktite this right????
Put in the new oil seal.
Put in the inner brake part
Put in the new spring
Put in the bearings
put in the new ratchet
put in the other part which compresses the spring and pushes the ball bearings in place
put in the outer brake part
Compressed all and put on the new snap ring.
Still lots of play.
Any thoughts. and dont tell me I need a new f ing shaft...
Is it possible that when the winch is powered and running the gears inside tighten everything up, since I understand sometimes the snap ring snaps?
Just got off the phone with Ron at Warn who rebuilds them X 3031.
States that all of the ratchets do have some play in them. its not uncommon and he does not feel a new style shaft is needed.
Also stated to make sure the snap ring (black one that goes on the end of the shaft is FLAT SIDE OUT) This helps to keep the brake from flying off.
He also said the brake does not start to grab until 300 pounds or so and it will tighten up a bit.
FWIW. Stated the new brass busing and the oil seal (first items to go on the shaft ouside of the housing) need to be driven in with the cardboard spacer so that the oil seal is flush with the housing.
Hope it helps someone.
