81fj40 alternator
North Carolina
Replaced alternator in my fj40 and wiring was rigged up weird to the old one so now I’m trying to figure out what goes where
Black w/ yellow tracer stripe is your IG wire or leed
The solid yellow is your N or L terminal
White w / blue tracer large guage wire is your B+ ring terminal
There are 2 B+
Terminals
Thai will be the larger 6mm x 1.0 one
Hope this helps ?
Your ring terminal is compromised and needs replacement before u install
FYI
It’s a issue
How is it compromised? And I’m sure I can figure it out with your info thank you
fatigued ring termial at the bend
then
broke insulation will snap these fragile corroded copper lead
this is FULL battery voltage remember
were u get the blue repair connector ?
thanks
NO 2 wires go to any SINGLE terminals ?
NO NO
BAD BAD
you will blow your s#it up !
Does this photos tell you clearly how to hook it up ?
Just did a full knuckle rebuild Not good with electrical though so thank you
your fine
im here to assist you in any way i can :)
did you Rauchphase the 2 weather boots also by chance ?
i have a better idea here
Please watch in detail my ALTERNATORs Repair kits technical TECH video below
it ill help you in a major way do this correctly the first time and walk away confident too .//
