Hello all, I am new here and also new to my rhd 81. Was wondering what some of you are using on an 80 series - some trail, some road, bit of everything. I will be sticking them on my 15x8 rims.
Check the FAQ under See how those accessories look. There is a discussion on members tires choices. You will get alot of different opinions as tire choice has alot to do with the type of terrain you wheel, tolerance to road noise, weather where you live, etc... You can also search and you will find enough tire discussion to keep you reading for a long time.
If you go in the main 80 Series Tech section there is a sticky up at the top that Romer has well set up. Click on the Updated FAQ sticky then scroll down a little and you will see "Want to see how those accessories look" written in yellow. Click on that and you will get another window that will have a list and you can click on the link that says Forum member tire choices. Just click around and play with things and you will get an idea of how this forum is set up. That is honestly the best way to learn it all. Good luck.
Another interesting option is to head to tirerack.com and look at the survey results for off road and all round tires. The results of the survey fairly closely correlate with the sentiments of this group. There are, however, some notable tires missing.
