- Joined
- Sep 16, 2007
- Threads
- 158
- Messages
- 1,286
- Location
- Los Angeles, California
- Website
- forum.ih8mud.com
my cruiser is 8000 pound what kind of winch should i get?... thanks
when your stuck up to the axle double the weight of the truck ,up to the frame triple it .this according to the usmc vehicle recovery course.8000 lbs seems kinda heavy for a cruiser.
which winch would you suggest that has a pulling capacity of at least 1,600 up to 2,400 pound?![]()
i have been doing the research, i will be ok with the 12,000 pound winch. in most sites the rule of thumb is 1.5 x the weight of the vehicle. the next question
does anyone know how PSI does a 40 series power steering pump puts out? for the mile maker hydraulic winch to work correctly the power steering pump need to put out 15 PSI of pressure. thanks![]()
i have been doing the research, i will be ok with the 12,000 pound winch. in most sites the rule of thumb is 1.5 x the weight of the vehicle. the next question i have is, should i get hydraulic? i have been looking at the Mile Marker HI12000 Hydraulic Winch. they are more expensive than electric. i will be traveling mostly solo.
I think your looking for gallons per minute, a flow rate; not PSI. IIRC the factory manual says you want to see 1100-1300 PSI out of the Toyota power steering pump. I do not recall the GPM flow rate though but real world use says the Toyota pumps might flow a little on the low side for a MM winch.
Nick
If you want high capacity and have PTO, I would have mounted hydraulic.
My Brevini 12000 can winch all day long up 22 meter a minute.
Land Cruiser winch, hydraulic
I've been drooling over your setup for a while now! I have a couple question for you though. Did you install a cooler (similar to the transmission cooler) in front of the radiator? I would rather keep the fluid cool that way than to have the big tank taking up room in the trunk. Also, I don't know much about the PTO on an 80 series. Can you power the wheels and the pump at the same time?
I can power the winch and weels at the same time.
There is no need for a big tank, like the one I made
I am going to redisign it, make it smaller.
The one I have now can take 100 liters, I think 50 liter will be enough.
http://www.sugarlump.no/cruiser/80_Winch.html
