According to an Aussie spec sheet I have from sometime in the 2000s (says was printed in 2001) the gear ratio for both solid axle 105 and IFS 100s were as follows...
4.30s for the petrol models (1FZ-FE)
4.30 for the turbo diesel models (1HD-FTE)
and 4.10s for the non-turbo diesel models. (1HZ)
It seems like an odd gearing set up, but that's what the spec sheet says directly from Toyota. Here it is on my website if you want to see for yourself...
http://www.brian894x4.com/LC100specs.jpg
It doesn't call the 105, the 105 on the spec sheet. The 105 comes in Standard, RV and GXL trims. The 100 also came in GXL trims, but not Standard and RV. Also, only the 105 had the petrol 1FZ-FE, not the 100.
I'm 90% sure that the axles and diffs are indentical to the 80s, but I seem to recall that the birfs or something along the front end was slightly different, perhaps updated after the 80 went away and I'm not 100% sure if they are absolutely compatable. But I would guess the rear axle and the front diff is probably exactly the same, at least.
One of the compatability issues may have to do with the fact that most, if not all 105s, came with manual hubs, so the birfs and hubs will be slightly different for that set up.
Unfortunately, this is for Australia and probably pretty close to the same for most anywhere in Southern Africa and the Pacific. The Middle Eastern Land Cruisers seem to have a set up unique to that region, so it may be entirely different as far as gear ratios and engine options, but I'd still bet at least 90% of the set up is the same as the 80 series.
