80 to 105 upgrade help
Pittsburgh, Pa USA
Hello Gents
So im new to this forum and needs some help. So I am working on a out of the box build. I am using the Fj80 steering box using a drop pitman to GM 1 ton drag link ends on my custom build. The box required a rebuild and Redhead Recommended upgrading to the 105 kit. Problem im running into now is finding a pitman arm the still works with my setup. Figured I could consult with the toyota guys and get some help. Anyone have any recommendations on where I may find some different pitman arm options that fit the 105 shaft?
I think you are asking about other, not 105 stock options, but just in case or for anyone who stumbles across this later... OEM is still available. Most vendors who sell the kit in the US sell the sector shaft, the pitmann arm and the nut and washer together I think. I ordered mine from PartSouq, then Joey started stocking them at Wits' End a few weeks later.
4411160060 SHAFT, CROSS
4541160360 ARM, PITMAN
9017022058 NUT, CASTLE(FOR PITMAN ARM)
9451102200 WASHER,SPRING
Jason
