80 = Stump Puller?
KIND
O.K., just pulled the stump from a 15yo Maple in our front yard with the 80. Cut all the accessible roots with an ax, so we were only working against the tap root. It took about ten good hard yanks and down it came. The 80 never showed any signs of damage or made any funny noises. Even when the rear was off the ground 12" during a couple of the yanks.
My question is should I be concerned? Should I pay any particular attention to any specific item on the drive train? Now that the adrenalin has worn off, I'm second guessing myself and the tank-like quality of the 80. REASURE ME MUD!!!!!
BTW - My neighbor (hardcore chevy lover, UAW works at the local chevy truck plant) came out and laughed. Told me to come and get his 2500HD when the Jap crap gave up. :flipoff2:
No, too caught up in the moment. Gotta do another tree in a week or so. I'll try to remember it then :hillbilly:
I'd say check your frame to make sure you didn't tweak it.
Listen for new gear whines while driving around. I'd be nervous too, but if you didn't blow anything up in the process, and there are no visible signs of deformation, run it!
Personally I would have taken your neighbor up on his offer. That's one thing I would never do with my 80. But if it worked for you then more power to ya :grinpimp:
I helped a friend pull out some old bushes this weekend in front of his house. His FJ80 wouldn't pull them out alone, so instead of getting throttle happy & possibly tweaking something, we hooked my FZJ80 up as well. With two vehicles pulling, the bushes came out no problem.
There's an old saying: "Work smarter, not harder." :)
........ The 80 never showed any signs of damage or made any funny noises. Even when the rear was off the ground 12" during a couple of the yanks.
My question is should I be concerned? Should I pay any particular attention to any specific item on the drive train? Now that the adrenalin has worn off, I'm second guessing myself and the tank-like quality of the 80. REASURE ME MUD!!!!!....... :flipoff2:
My only concern would be to make sure that when you're doing the tugging, that you're in a "forward-going" gear, NOT reverse. The R & P in your diffs is the strongest going forward. You're more likely to damage a diff pulling in reverse, the way the gears are designed. So if your rig is well maintained, yank away, just be going the right direction.
I pulled out a buddy's fence post with my 80. It was anchored with concrete about a foot deep in the ground. Didn't even get 2000 RPM and the thing came flying out.
lol, what?
I wouldn't worry much personally. Out of curiosity, where did you attach the strap/chain?
I remember when I was about 11 years old, my dad and I used his then 2-year-old, stock '95 FZJ80 to pull some huge (10 ft+ tall) bougainvillea plants out from next to the house. They were so full of thorns we could barely make a dent in them with the chainsaw.
So my dad hooks up the tow strap to the Reese hitch and tells me hop in, throw it in drive and go ahead slowly. Keep in mind this is on stock Michelin LTX M/Ss on thick St. Augustine grass. It seemed to stress a bit then started spinning one of the front tires.
I had no idea what the CDL was at the time but I knew that if I put the transfer in low range, this light on the dash would come on and it would pull like a tractor. So I throw it in low low and proceed to snatch these huge bushes right out of the ground.
I don't think we ever could untie the knots in that tow strap.. think we ended up cutting it. Anyway, that was probably my first experience with the 80's tank-link abilities..
:cheers:
I left about 5' of the trunk sticking out of the ground for leverage, that's what was causing the rear to lift during the yanking. I used a 30K strap doubled around the trunk w/ a "D" ring on the pintle pull bar on the Reese hitch.
Pretty fawking insane looking back now, but I gotta tell ya, I was sick of swinging that fawking ax.
Oh, and all pulls were w/ the vehicle going forward.
I think it's fine.
If anything I'd have worried about the leverage of the hitch screwing up the rear frame rails where it bolts on, but considering the hits that my hitch has taken wheeling, I don't think you have anything to worry about..
