80 series transfer leak
hay mates I have a oil leak between gear box and transfer case .Cleaned it up, it seems to becoming from a square hole in the moulding of transfer case.Its a 1995 4.2.Is this hole been put in to let you Known the seals are leaking.If so can i block hole and put pipe between transfer and gear box fillers.
if you have an aoyomatic transmission then it sounds like the auto tans has a bad rear seal, just pull the transfer and replace the seal, if you have a manual trans then it sounds like the transfer seal is bad and is pumping the oil out of the transfer, either way i would remove the transfer and replace the seals, probably do a reseal and rebuild on the transfer while i had it out too. good luck
Spoke to someone today.It sounds like thay put small hole in transfer case for the 80series so you known when transfer csae seal is leaking.So you dont suck TC oil in auto.My is a manual so i will plug hole untill I have some coin saved
