For Sale 80-series Nitro axles, birfields. 4.88 Nitro R/P, knuckle kit. Slee S/S brake lines. Brand new
TurboDennis
Toronto, ON
EVERYTHING SOLD, except Nitro knuckle kit ($105 shipped)
No longer needed. Purchased from Slee a few years ago, never installed, have been sitting since. There was some minor surface rust on the axles from moisture in the air. It wipes off easily with a rag and WD-40, but leaves a stain, as seen on pictures. Would clean up nicely with some scotch-brite pad.
$950 SHIPPED for both front and rear kits. Includes rear axle shafts (for locked diff, but should work on non-locked as well), front kit with 2 axle shafts and birfields. ( AX TBIRF-FJ80KIT and AX TFF-FJ80 ) Early trucks will need 95+ drive flanges for the birfields (i have used flanges for sale, if needed). If you have ABS, you will need to press on your ABS rings on the birfields.
4.88 ring and pinion sets, for both front and rear. (T8R-488R-NG and TLC-488-NG) BNIB. boxes are a little beat up, but gears inside are perfect.
29-spline nitro pinion flange kit for the front diff (YOKTOYFITKIT-29). Required for the 4.88 front gears above. $450 SHIPPED for both gear sets, and flange kit
Nitro front knuckle rebuild kit. Part# KNCLKIT-FJ80 There is no wheel bearings in these kits. BNIB. $105 shipped
Slee S/S brake line kits, front and rear. STF1021 and STF1008 $200 SHIPPED for both sets.
More pics
Rear axles for elocker diff? Wanna separate?
Yes, for elocker diff, (as i mentioned in the description)
I would prefer to sell together, but i can separate - $400 shipped for just the rear.
Interested in the brake lines if the guy above me falls through.
