80 series emissions, same in Cali?
Pollock Pines,CA
does any one know irf there was a difference uin 80 series rigs for emissions? i am looking at rigs that may come from out of state and need to know if i will have an issue bringing it into california? thanks
As far as I know all 80's came with "50 state emissions"
I'm not 100% on this though. Maybe someone else can chime in.
They were not state specific. There were different emissions setups depending on year. IE: 91-92 was different from 93-94 (and some early 95 I believe) with PAIR, and then you have the 96-97 setup.
If you're bringing a rig into Cali, legally you will need to ensure that it is 100% stock emissions, smogged, and that it'll pass. People sometimes do things and sneak them by, but as I understand it the fines are fairly steep if you get caught.
A lot of what you can do also depends on the year you purchase, and which motor.
Check the VECI (vehicle emissions control information) label. It's somewhere under the hood. Either on the hood itself, the air cleaner or the radiator support. (I don't feel like popping my hood right now or I'd tell you where mine is. :) )The bottom will say something like "this vehicle conforms to all federal emissions standards in place for X model year"
If it's a CA emissions rig, it'll say that in the same place.
Since it's a used vehicle, it just has to have everything it originally came with (emissions-wise) and it has to pass the inspection. I'm pretty sure the 80s were all 50-state.
I think your only drama might be that cat. converters go bad at about the age of this rig, consequently may have to dole out the big $ for a new cat when bringing in and registering in the golden state.
This PDF addresses used vehicles in the bottom right paragraph, where it says "All gasoline-powered vehicles,new or used, being registered for the first time in California must pass the California Smog Check. A vehicle will fail the California Smog Check if it is not equipped with the originally required smog devices."
That assumes that said state knows what it's looking for. Plenty of people have snuck vehicles past that do not meet the requirements.
For example, hollowed out cats. Or removing PAIR in such a way that it still appears stock.
(Note: I do not recommend or condone this. But if I were buying a vehicle in a pinch that didn't quite meet the requirements, it might be something I'd consider.)
I got to do a fair amount of research on this while shopping for my rig, and with respect, it assumes nothing of the sort. The emissions check is performed in California prior to tags being issued, and checks performed out of state don't interest our DMV in the least. If the vehicle doesn't pass California inspection, DMV won't give you tags until it does. If it can't be made to pass, you're out of luck.
Now it's true that you may or may not pass inspection with the things you said, but that has to do with the diligence of the shop doing the inspection in California, not about what shops or inspectors outside California have done prior to the vehicle's arrival.
The easiest thing to do is to buy one that is already titled in California. The onus is then on the seller to provide proof of compliance at the time of sale. Otherwise, be assured that you will have to do a California emissions inspection, and how much gambling you want to do around that is completely your call.
Sorry, I wasn't clear. I should have said something like: "said state inspector", as in the inspector from Cali who is doing the checking. I realize what I actually said holds a quite different meaning. ;)
Very true and as I already mentioned I wouldn't recommend that someone do something "shady" such as hollowing out the cats. For one if you get caught it's a quite hefty fine.
I've rescued two trucks from Cali. Don't need to be dragging any more in there. :p
