80 series electrical problem
yakima
Hi I have a 1995 80 series.. we were fighting squirrels and my dog got underneath the rig and yanked out the AC and oil pressure harness I managed to get it installed but oil pressure switch was not working I tried fuses but all good then I was trying a continuity test i took out the 15 fuse for ECU-is and tested (idiot I was to do that) and now the rig runs but no instrument cluster Ac nor power windows work everything else does HELP!!
Did you check all your fuses? Sounds like you blew one. I think all those items run on the cig lighter fuse.
Yes I checked the fuses even the AMI all good the Rig runs lights work just no cluster AC/Heater and power windows also Greatly appreciated for your response 👍🏻
Just saw this is your first post. Welcome to MUD !!
