80 series egr code
Virginia beach
Hey everyone, I have a check engine light for my egr and what I looks like is because the port on the intake manifold is clogged what is the best way to clean that out so I can get the code go go away?
Easiest is just to bypass it. That port tpasses through and comes out bottom side of intake clamshell.
Or dissasemble intake, then carefully clean tube by hand with a drill bit. Do not break it off in the passage ;)
What exactly you mean by pass it
Bypass.
To go around.
To deviate course to avoid obstacle
A secondary chanel to allow proper flow around a blockage.
Thats a solid tube that runs through the intake. Just run your new vacuum line from current origin down between the intake runners and continue it towards its current end destination. It can be tucked away decently to avoid the overly attentive visual inspectiors if necessary. Ive seen folks run a dummy line off the top just so no plugs or dead ends are visible.
No pics of bypass but here is one of the nipple in question. Use your hands and eyes. It travels straight down and out the other side. Hard to get to but not impossible. Just run one line and bypass the intake pass thru or clean it as described here with steel wire or the like.
