80 series e-locker 3rd member 4.30 ratio w/ front R&P to match - $650
north of seattle
Complete rear Electric Locker 3rd member, rebuilt 4.30 ratio gears, with actuator will fit 93-97 80 series ( fzj80 hdj80 ) with factory lockers. Also includes front ring & pinion in 4.30 ratio to match. Perfect for stock vehicles looking for a little more pep, or to match with 285/75/16 tires. Also great for vehicles with bigger tires that are running a diesel like 1hz or 1hdt or cummins.
$650 for all - will not seperate
Are the R&P's factory or aftermarket? Thanks
factory
oem toyota
Do you have any of the wiring for the locker?
How does that gear compare to the stock unlocked gear?
e-locker
no wiring, just the pigtail on the actuator.
So if I read this right, you have a rear R&P in a 3rd member with the electric locker, and a R&P for the front. Is that correct? Thanks
yes that is correct
Yes that is correct. It comes with everything in the photo. Rear complete e-locker 3rd member 4.30 ratio. and a 4.30 ratio RING & PINION for the FRONT
Yes I still have it
yes i still have it
