80 body lift
i just bought an 80 and i need to do a body lift on it, i have a good write up on how to do it so thats not the problem, the problem is what do i do for the rear bar because apparently you cant lift them, has any one lifted theres with the body lift if so do you have pics or dose any one know how to lift there rear bar after the body lift, i cant justify spending 995 on a rear tube bar.
thanks
Duck, Welcome! Please post pics of your rig.
BTW, why not just lift the suspension with springs and shocks?
I did a 1" body lift and didn't do anything to the "rear bar". Since I don't know what a rear bar is, but I'm guessing it's another name for a rear bumper. There is a 1" gap now, but it doesn't bother me at all. It is hardly noticeable.
Welcome!! :flipoff2:
But a body lift? You have an 80, not one of those other wannabe's. Your 80 deserves a lift, through a suspension upgrade. Leave the body lifts for the vehicles that are far less capable, that have to "pretend" to be a tank w/ high clearance.
The 'rear bar' is a frame rail. There is no way to lift it short of cutting it off the frame and re-welding it higher, which would compromise its integrity. Some people, me included, have cut that rear frame rail off and replaced it with a home made bumper, which could be installed higher.
-Spike
Hiya Duck, didnt know you already had an 80, maybe a different duck.. anyway, your stuck with the rear bar its actually the rear of your shassis. The best you can do is have a custom made tube bar that sits over the rear and angles up at the side to make it look ok for the body.
5"spring and 2" Body on the rear and 4"springs on the front. So it sits nice and l;evel. Also believe going to 6" on the 80's creates additional issues with the uni's and shafts..
Check the Link in my sig for the Bodylift instructions...
Ctach
LBD
Oh yeah Welcome to the Best 80 Series forum! :flipoff2:
You must be mistaking a 4Runner for an 80. :D 80's sit high in the rear normally after being lifted.
-Spike
It depends on how high you want to go. If money is no object a suspension lift will allow you to run a larger tire with more articulation and a better ride than stock. Body lifts, IMHO, are a cheap way to gain additional room for larger tires after doing the proper modifications to the suspension. I am very satisfied with my 6" suspension and 2" body lift running 38.5" x 11.00" tires.
Things that I ran into that I did not read about in A LOT of reading and research prior to the install are:
I had to cut, turn 180 degrees and reweld my transfer case shifter. The rearward angle prior to the modification caused it to hit on a linkage cross bar and stopped the transfer case from going into low range.
I did drop my radiator shroud as per the instructions, but also cut away some of the shroud at the bottom to insure it would not hit the fan when flexing.
I destroyed the rear most drivers side body mount because of some serious corrosion. Add in the cost of this in case it happens to you. This is more of an issue with us that reside in the rust belt.
Best of luck.....
ok, here goes. Cut the rear bar off the chasis rails. (Its not totally structural as some 80's have them bolted between the rails and some are welded). Get a new peice of steel and cut and bend it to the same shape as the bar you cut off. Weld on some flat peices of steel that will rest against the chassis rails and drill mounting holes in the flat peices on a 45degree angle that match the holes from the factory in the rails (where some bars are originally bolted to) make sure that your flat peices are the same height over standard that your body lift is as that will create your bumper lift. You will also have to notch the bottom of the new rear bar so that it fits around the bottom of both chasis rails obviously because the bumber covers the rail ends. Bolt it all on then cut off your bumperette brackets and re weld them higher to match the body lift. Bolt everything back together and your done. Remember that you will see the ends of the chasis rails to the height of the body lift. You may want to fabricate soemthing to cover them.
Ctach
LBD
wow LBD is alive, lol well yer it is the same duck, and yer i have read and re-read ya body lift how to do, went to cheezy the other day to get a quote on a bar, 995, pritty expensive.
andy way im going to do a 3 suspention and 2 body coss i can run 36" extream treckers with out it scrubben and it keeps the center of gravity lower and its cheeper coss i dont need to do pahnads, break lines ECT.
ill post pics of it later
-Spike
I guess you must be right, yeah sheesh what was I thinking???
All these years i've had a 4runner and i thought it was an 80 series!
gee thanks man, you've been really helpful!.:flipoff2:
Ouch, guess he's charging a bit more since the prototype, (mine).
