Your ammeter may not be able to handle it, not sure what the limit is. But your charging system will only take as much current as it needs from the alternator, not the full 80 amps unless you were winching or otherwise using something with a large amperage draw. So, if you're not going to run a winch, then the stock wiring will probably be fine (except for possibly the ammeter). If you are going to run a winch then I would replace both the positive and ground cables with heavier gauge.
I put a 200-amp alternator on mine, but replaced all my battery, alternator, starter, and ground cables with much heavier gauge, and replaced my ammeter with a voltmeter.
