80 alarm going off
New Hampshire
Since I have owned the 80 I have to either close all doors and lock them or leave ignition on. Must say more than inconveinient. If anyone knows how to remove and/or bypass the alarm without doing anything to the computer, and not being able to use the existing horn. Today I took apart my dash and unearthed the wiring leading from the in dash switch to the alarm sensor box under the driver seat. Electrical isn't my forte' to say the least. My 80 is a June of 92. Thank you all in advance for any help.
Derek
First, is the alarm factory? I would guess probably not.
As an old mechanic, My first job on buying a car is to remove the alarm system. First because it is more of a mechanic aggravater than a theft deterrent. Imagine trying to work when the alarm keeps going off every time you pull on a wrench! How often do you ignore alarms when you hear them screaming. Do you call the police? Probably not and neither does anyone else. Thieves are not afraid of alarms, but mechanics are!
Second because it is a second-rate aftermarket system that I don't have an instruction book for. It is usually installed by a second rate tech who has no real knowlege of Japanese electrical needs, and usually causes problems without really solving any. Most pro thieves are privy to most alarm systems.
There are better ways to deter thieves if you are tricky and thieves are not privy to them. One is to re-ground the fuel pump or EFI relay. The ground usually goes right to chassis. Instead, route it thru the buzzer switch in the ignition lock.
Real-life scenario is that a pro thief will break glass, slide-hammer out the ignition lock and drive away with the alarm screaming, all in about 30 seconds. With the key switch grounding the fuel source, you will need a tow, not a new truck! With the lock forced out the fuel will not deliver and the truck is dead. If you can Macgyver the wires you can drive, but a thief will not take the time. He will find another victim.
